Oil Pressure Sender
Material
Removal and Installation
Material
Item | Specification |
Pipe Sealant with Teflon® XW7Z-19554-AA | WSK-M2G350-A2 |
- With the vehicle in NEUTRAL, position it on a hoist.
[/*] - Remove the 5 bolts and the RH splash shield.
- To install, tighten to 9 Nm (80 inch lbs.).[/*]
- Disconnect the oil pressure sender electrical connector.
[/*] - Remove the oil pressure sender.
- To install, tighten to 15 Nm (11 ft. lbs.).[/*]
- To install, reverse the removal procedure.
- Apply pipe sealant with Teflon to the oil pressure sender threads.[/*]
