Activating/deactivating the autolock feature (2005-2007 models only)
The autolock feature can be turned on or off using the following procedure. Before starting, make sure the ignition is in the 1 (LOCK) position and all vehicle doors are closed.
NOTE: Some 2005 models were not equipped with automatic door locks.
You must complete Steps 1-5 within 30 seconds or the procedure will need to be repeated.
1) Turn the ignition to the 3 (RUN) position.
2) Press the power door unlock control (on the door panel) three times.
3) Turn the ignition from the 3 (RUN) position to the 1 (LOCK) position.
4) Press the power door unlock control three times.
5) Turn the ignition from the 1 (LOCK) position to the 3 (RUN) position.
6) The horn will chirp once to confirm programming mode is entered/active.
7) Press the power door unlock control on the door panel one time.
8) Press the power door lock control on the door panel one time.
Note: The horn will chirp once to confirm the feature is OFF, or the horn will chirp and then honk to confirm the feature is ON.
9) Turn the ignition to the 1 (LOCK) position.
Note: The horn will chirp once to confirm the programming mode has been exited.
10) Repeat the previous procedure to turn the feature on or off.
