1 - 17 of 17 Posts
FLOOR CONSOLE
Removal and Installation
All Vehicles
1. Position the seats forward and remove the 2 rear bolts.
2. Position the seats rearward and disconnect the battery.
3. Position the parking brake handle to the full-up position.
4. Remove the transmission selector lever bezel.
5. Release the parking brake handle boot from the floor console finish panel.
Mariner
6. Remove the floor console top panel.
All Vehicles
7. NOTE: On Escape, if removing the floor console storage bin, squeeze the front and rear of the storage bin to release the retaining tabs from the floor console finish panel.
-Remove the floor console finish panel.
-Disconnect the electrical connectors.
8. Remove the 6 bolts and remove the floor console.
9. To install, reverse the removal procedure.
Is it round? Unscrew it from the shaft. Otherwise, there is probably a hidden screw near the bottom. I think that is more the norm for Ford. I'm not sure about the Escape though...
On the front side of the shifter, about a half inch under the trigger, there's a hex screw that secures the top section to the shaft. Pop that out, and...the missus stopped me from disassembling further. lol
:lol:
I hope someone can help...
The indicator light in the center console shift assembly just went out on my 06 Escape. I removed the top piece & shift knob to take a look at the bulb for replacement but couldn't figure out how to get to it. The bulb was too tight to rotate & disconnect from the top & I don't know how to get underneath the interior panel. In the process I accidentally unplugged my O/D wire from inside?! The wiring isn't torn... just looks disconnected. It's still attached to the shift knob but I don't know where it plugs back into... ??
The dealer over the phone couldn't tell me a replacement bulb number, and said that it would need a whole new shift assembly. Is that true for just a burnt bulb? Everything else works fine (except my O/D unplugging issue).
I'd really appreciate any advice before resorting to taking it in!
1 - 17 of 17 Posts
