1 - 1 of 1 Posts
FRONT BUMPER COVER
Escape Is Shown, Mariner Is Similar (Part 1)
Escape Is Shown, Mariner Is Similar (Part 2)
Removal and Installation
CAUTION: Prior to removal of the front bumper cover, place tape at the corners of the bumper cover and below the headlamps to prevent damage to the paint.
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Remove the 6 pin-type retainers (3 each side).
3. Remove the 4 fender splash shield bolts (2 each side).
- To install, tighten to 8 Nm (71 lb-in).
4. Remove the 4 air deflector bolts.
5. Remove the 2 center front bumper cover pin-type retainers.
6. Remove the 2 front bumper cover outer pin-type retainers (1 each side).
7. If equipped, disconnect the fog lamp electrical connectors.
8. Remove the 2 upper bolts and the front bumper cover.
9. To install, reverse the removal procedure.
- Position the front bumper cover.
- Push inward on the sides of the bumper cover near the bottom corner of the headlamp until you feel the bumper cover snap onto the bumper slides.
1 - 1 of 1 Posts
