1 - 1 of 1 Posts
Removal and Installation
WARNING: Never probe the connectors on the air bag module or pretensioner. Doing so may result in pretensioner or air bag deployment and may result in personal injury. Failure to follow these instructions may result in personal injury.
WARNING: The safety belt pretensioner is a pyrotechnic device. Always wear safety glasses when repairing an air bag equipped vehicle and when handling a safety belt buckle pretensioner or safety belt retractor pretensioner. Never probe a pretensioner electrical connector. Doing so may result in pretensioner or air bag deployment. Failure to follow these instructions may result in personal injury.
WARNING: To avoid accidental deployment and possible personal injury, the backup power supply must be depleted before repairing or replacing any front air bag or side air curtain supplemental restraint system (SRS) components and before repairing, replacing, adjusting or striking components near the front air bag or side air curtain sensors, such as doors, instrument panel, console, door latches, strikers, seats and hood latches.
Refer to the appropriate workshop manual to determine the location of the front air bag sensors.
The side impact sensors are located at or near the base of the B-pillar.
NOTE: To deplete the backup power supply energy, disconnect the negative battery cable and wait at least one minute. Make sure to disconnect auxiliary batteries and power supplies (if equipped). Failure to follow these instructions may result in personal injury.
NOTE: The passenger seat is equipped with an occupant classification sensor (OCS) system and is replaced as an assembly. For additional information, refer to Section 501-20B.
NOTE: The power seat and manual seat are similar.
WARNING: To reduce the risk of serious personal injury, read and follow all warnings, cautions and notes in the supplemental restraint system (SRS) depower/repower procedure. Failure to follow these instructions may result in personal injury.
1) Remove the front seat and depower the supplemental restraint system (SRS). See notes, above.
2) Remove the 4 front seat track bolts.
* To install, tighten to 23 Nm (17 lb-ft).
3) If equipped, disconnect the front seat cushion heated seat grid electrical connector.
4) Remove the front seat cushion cover from the front seat cushion pan.
5) Install the front seat and repower the supplemental restraint system (SRS). See notes, above.
6) To install, reverse the removal procedure.
1 - 1 of 1 Posts
