Brake Caliper, Front - Hybrid
Material
Item | Specification |
High Performance DOT 3 Motor Vehicle Brake Fluid PM-1-C (US); CPM-1-C (Canada) | WSS-M6C62-A |
Silicone Brake Caliper Grease and Dielectric Compound XG-3-A | ESE-M1C171-A |
Removal and Installation
WARNING: Use of any other than approved DOT 3 motor vehicle brake fluid will cause permanent damage to brake components and will render the brakes inoperative. Failure to follow these instructions may result in personal injury.
WARNING: Carefully read cautionary information on product label. For EMERGENCY MEDICAL INFORMATION seek medical advice. In the USA or Canada on Ford/Motorcraft products call: 1-800-959-3673. For additional information, consult the product Material Safety Data Sheet (MSDS) if available. Failure to follow these instructions may result in personal injury.
CAUTION: Brake fluid is harmful to painted and plastic surfaces. If brake fluid is spilled onto a painted or plastic surface, immediately wash it with water.
CAUTION: Do not allow brake fluid to overflow from the master cylinder reservoir. Brake fluid may damage the high-voltage components.
NOTE: The rear
brake pads will wear at approximately twice the rate of the front brake pads.
- With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Maintenance/Service and Repair.
- NOTE: These steps must be followed to prevent the accumulator from charging and pressurizing the brake system.
Disconnect the battery. For additional information, refer to Battery.
- Remove the battery junction box (BJB) fuses 24 (50A) and 31 (50A).
- Remove the brake caliper clip.
- Loosen the brake caliper jounce hose at the brake caliper.
- To install, tighten to 20 Nm (15 ft. lbs.)[/*]
- Remove the 2 brake caliper dust boot caps.
- Remove the 2 brake caliper guide bolts.
- To install, tighten to 45 Nm (33 ft. lbs.)[/*]
- Remove the brake caliper.
- Unthread the brake caliper from the brake caliper jounce hose.[/*]
- NOTE: Make sure that the brake caliper jounce hose is not twisted.
To install, reverse the removal procedure.
- Bleed the brake system.[/*]
hr
Brake Caliper, Rear - Hybrid
Material
NOTE: The rear
- Remove the battery junction box (BJB) fuses 24 (50A) and 31 (50A).[/*]
- NOTE: Install new copper washers.
Remove the brake caliper jounce hose flow bolt and discard the 2 copper washers.
- To install, tighten to 35 Nm (26 ft. lbs.)[/*]
- To install, reverse the removal procedure.
hr
Brake Caliper Anchor Plate - Hybrid
- Remove the brake pads.
- Remove the 2 brake caliper anchor plate bolts.
- To install, tighten to 175 Nm (129 ft. lbs.)[/*]
- Remove the brake caliper anchor plate.
- To install, reverse the removal procedure.[/*]
hr
Parts | OEM Part | Price (Q1 2009) | |
