1 - 1 of 1 Posts
Specifications
Front Disc Brake
Brake disc
Minimum thickness (base brake system)22 mm (0.86 inch)
Minimum thickness to machine (base brake system)22.6 mm (0.88 inch)
Minimum thickness (4 wheel disc brake system)24 mm (0.95 inch)
Minimum thickness to machine (4 wheel disc brake system)24.6 mm (0.97 inch)
Rear Disc Brake
Brake disc
Minimum thickness11.0 mm (0.43 inch)
Minimum thickness to machine11.6 mm (0.45 inch)
hr
Brake Disc, Front - Hybrid
Removal and Installation
  1. NOTE: These steps must be followed to prevent the accumulator from charging and pressurizing the brake system.
    Disconnect the battery. For additional information, refer to Battery.
  2. Remove the battery junction box (BJB) fuses 24 (50A) and 31 (50A).
  3. Remove the brake caliper anchor plate.
  4. Remove the brake disc.
  5. To install, reverse the removal procedure.[/*]
hr
Brake Disc, Rear - Hybrid
CAUTION:
Do not allow brake fluid to overflow from the master cylinder reservoir. Brake fluid may damage the high-voltage components.
NOTE: The rear brake pads will wear at approximately twice the rate of the front brake pads.
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Maintenance/Service and Repair.
  2. NOTE: These steps must be followed to prevent the accumulator from charging and pressurizing the brake system.
    • Remove the battery junction box (BJB) fuses 24 (50A) and 31 (50A).[/*]
  3. Remove the brake pads.
  5. If the brake disc binds on the parking brake shoe and lining, remove the adjustment hole access plug and retract the parking brake shoe and lining by rotating the adjuster.
  6. To install, reverse the removal procedure.[/*]
hr
Parts
OEM Part
Price (Q1 2009)
Rear brakes
Rotor5L8Z-2C026-BA
119.00​
Replace
Skill Level
Mfg. Warr.
Std.
See Brake Pad and use note combinations.
1 - 1 of 1 Posts
