TSB 07-5-6
03/19/07
CD4E - ENGINE STALLING ON ENGAGEMENT/STOPPING
FORD:
2005-2008 Escape
MERCURY:
2005-2008 Mariner
ISSUE
Some 2005-2008 Escape and Mariner vehicles equipped with a CD4E automatic transaxle and built from 8/1/2004 through 2/15/2007 may exhibit an engine stall when coming to a stop or when engaging the transmission into drive or reverse. This condition may be intermittent and often occurs after extended drives. There may be no diagnostic trouble codes (DTCs) stored. This may be caused by internal wear in the torque converter which prevents it from unlocking.
ACTION
SERVICE PROCEDURE
1. Inspect and repair all non transaxle codes per Workshop Manual (WSM) and Powertrain Controls/Emissions Diagnosis (PC/ED) manuals.
2. Use the Integrated Diagnostic System equipment to monitor the PIDs (Parameter Identification) for TC_SLIPACT as the stall is occurring.
a. If the slip is greater than 20 RPM, the stalling is not transaxle related. Repair following PC/ED procedures for engine stalling condition.
b. If TC_SLIPACT is less than 20 RPM with the transmission in park or neutral, torque converter internal failure is the most likely cause, proceed to Step 3.
3. Remove the transaxle assembly and check the rotation of the torque converter in the bell housing. A failed converter will be difficult to rotate.
4. Remove the torque converter, drain the automatic transmission fluid (ATF) and refill the CD4E transmission assembly using MERCON(R) V ATF.
5. Install a new torque converter and reinstall the transaxle assembly.
6. Back flush the transmission cooler system as described in the WSM, Section 307-01A.
Parts Block
DEALER CODING
03/19/07
FORD:
2005-2008 Escape
MERCURY:
2005-2008 Mariner
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
PART NUMBER | PART NAME |
8L8Z-7902-A | Torque Converter |
XT-5-QM | MERCON(R) V Automatic Transmission Fluid |
070506A | 2005-2008 Escape/Mariner 4X2 2.3L: Diagnose And Replace The Torque Converter, Includes Time To Remove And Install Transmission, Backflush The Cooler System (Do Not Use With 7000A, 7000A11, 7000A12, 12650D) | 5.2 Hrs. |
070506A | 2005-2008 Escape/Mariner 4X4 2.3L: Diagnose And Replace The Torque Converter, Includes Time To Remove And Install Transmission, Backflush The Cooler System (Do Not Use With 7000A, 7000A11, 7000A12, 12650D) | 5.8 Hrs. |
070506A | 2005-2008 Escape/Mariner 4X2 3.0L: Diagnose And Replace The Torque Converter, Includes Time To Remove And Install Transmission, Backflush The Cooler System (Do Not Use With 7000A, 7000A11, 7000A12, 12650D) | 5.9 Hrs. |
070506A | 2005-2008 Escape/Mariner 4X4 3.0L: Diagnose And Replace The Torque Converter, Includes Time To Remove And Install Transmission, Backflush The Cooler System (Do Not Use With 7000A, 7000A11, 7000A12, 12650D) | 7.5 Hrs. |
7902 | 30 |
