TSB 08-3-1
02/18/08
MALFUNCTION INDICATOR LAMP (MIL) ON WITH
DIAGNOSTIC TROUBLE CODE (DTC) U2062
FORD:
2005-2008 Escape Hybrid
MERCURY:
2006-2008 Mariner Hybrid
ISSUE
Some 2005-2008 Escape Hybrid and 2006-2008 Mariner Hybrid vehicles may exhibit an MIL on with a DTC U2062 in the brake system control module, part of the hydraulic control unit (HCU).
ACTION
SERVICE PROCEDURE
Diagnose and fix any other DTC's before performing this TSB for DTC U2062. If the DTC U2062 is present alone or after diagnosing other DTC's perform this Service Procedure.
1. Disconnect the battery ground cable. For additional information, refer to Workshop Manual (WSM), Section 414-01.
2. Locate the two grounds for the ABS controller using the wiring diagram. Grounds for 2005 to 2007 are G102 and G104. 2008 grounds are G109 and G110. The grounds are located on the right hand side frame rail under the hydraulic control unit (HCU). (Figure 1)
3. Disconnect the grounds G102/G104 or G109/G110, clean the ground stud threads and contact sur[ace. If the vehicle was built prior to October 2005, replace the two ground studs and nuts with the updated service parts.
4. Disconnect connector C1462 the 47 pin HCU connector and remove red plastic lock from inside the connector. (Figure 2)
5. Open the back cover of connector C1462 and locate the black ground wires in pin locations 16 and 47. Remove pins 16 and 47 from connector C1462. (Figure 3) Remove tape from harness loom and cut the two ground circuits 1 inch into the harness loom. Tape the ends of the ground circuits and re-tape the harness loom into original position using vinyl tape or equivalent.
6. Using the ground wires provided in the jumper harness service kit, insert the pins into C1462 at pin locations 16 and 47. (Figure 3) Tape the jumper harness service kit wires to the existing harness until you reach the ground locations G102/G104 or G109/G110. Install the red plastic pin terminal lock into C1462 and connect to the HCU. (Figure 2)
7. Locate the existing ground eyelets for G102/G104 or G109/G110 that were removed in Step 3. (Figure 1)
8. Cut the existing ground eyelets for G102/G104 or G109/G110 near the harness and tape exposed ends to the existing harness.
9. Route the ground jumper harness service kit eyelets to the ground studs on the HCU bracket and secure the grounds. (Figure 4)
10. Connect the battery ground cable. For additional information, refer to Workshop Manual (WSM), Section 414-01.
Parts Block
DEALER CODING
TSB 08-3-1
02/18/08
FORD:
MERCURY:
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
PART NUMBER | PART NAME |
W711254-S437M | Ground Stud |
W705790-S901 | Nut |
8M6Z-13N850-A | Harness Service Kit |
080301A | 2005-2008 Escape Hybrid, 2006-2008 Mariner Hybrid: Install Ground Jumper Harness Service Kit, Includes Time To Check For DTCs (Do Not Use With 12650D) | 1.0 Hr. |
2C215 | X1 |
