TSB 08-4-19
03/03/08
BRAKE GRAB - DAMP CONDITIONS
FORD:
2005-2008 Escape Hybrid
MERCURY:
2006-2008 Mariner Hybrid
ISSUE
Some 2005-2008 Escape Hybrid and 2006-2008 Mariner Hybrid vehicles built on or before 2/19/2007 may exhibit brake grab in damp conditions. This is noticeable during the last few feet of a normal stop during the transition between regenerative braking and normal friction braking approximately 10 MPH (16 Km/h) and below. The transition is necessary as regenerative braking function alone is incapable of bringing the vehicle to a complete stop.
ACTION
SERVICE PROCEDURE
2005-2006 Escape Hybrid and Mariner Hybrid - Built On Or Before 05/24/2005
1. Follow WSM, Section 206-00 for front and rear brake rotor service. Machine the brake rotors or replace if required.
2. Follow WSM, Section 206-03 for front disc brake pad service and install new front brake pads.
3. Follow WSM, Section 206-04 for rear disc brake pad service and install new rear brake pads.
2006-2008 Escape Hybrid and Mariner Hybrid - Built Between 05/24/2005 - 02/19/2007
NOTE
FRONT BRAKE SERVICE ONLY.
1. Follow WSM, Section 206-00 for front brake rotor service only. Machine the brake rotors or replace if required.
DEALER CODING
03/03/08
FORD:
MERCURY:
ISSUE
ACTION
SERVICE PROCEDURE
NOTE
MT080419 | Claim Labor As Actual Time Or Use SLTS Operation If Available | Actual Time |
2001 | 42 |
