1 - 1 of 1 Posts
TSB 09-2-4
02/09/09
REAR BRAKE NOISE
FORD:
2005-2008 Escape Hybrid
MERCURY:
2006-2008 Mariner Hybrid
ISSUE
Some 2005-2008 Escape and Mariner Hybrid vehicles may exhibit a cyclical rear brake noise during low speed driving, going around corners and/or when driving in wet conditions. The noise results from a lack of parking brake use causing corrosion buildup inside the drum-in-hat parking brake surface and parking brake shoes becoming off-center. The parking brake should be set each time the vehicle is parked to prevent this concern.
ACTION
SERVICE PROCEDURE
While in a parking lot, not exceeding 20 MPH (32 Km/h), lightly apply the parking brake bringing the vehicle to a stop. Shift the vehicle to park. Then, with foot off brake, release the parking brake, reapply and release. Per vehicle's owner guide, advise the customer to set and release the park brake each time the vehicle is parked to prevent this concern.
OPERATION
DESCRIPTION
TIME
090204A​
2005-2008 Escape Hybrid, 2006-2008 Mariner Hybrid: Follow The Service Procedure To Correct The Rear Brake Noise Condition
0.3 Hr.​
DEALER CODING
BASIC PART NO.
CONDITION CODE​
2C026
07​
1 - 1 of 1 Posts
