TSB 05-13-8
07/11/05
REAR DISC BRAKE GRIND, RUBBING OR THUMP NOISE
FORD:
2005 Escape Hybrid, Escape
MERCURY:
2005 Mariner
This article supersedes TSB 05-9-25 to increase the labor operation time.
ISSUE
Some 2005 vehicles may exhibit a rear disc brake grind, rubbing or thump. The noise may be more noticeable during cool or wet conditions, and usually occurs during initial brake application after setting over night. This may be due to the composition of the brake lining material.
ACTION
Machine the rear rotors and install new rear disc brake linings made of revised material. Refer to Section 206-04 of the Workshop Manual.
Parts Block
6L8Z-2200-B - Brake Lining
OPERATION: 051308A
DESCRIPTION: 2005 Escape, Mariner, Escape Hybrid: Machine The Rear Brake Rotors And Install New Rear Disc Brake Linings (Do Not Use With 2001B, 2001B1, 2001B3P, 2001B3PT)
TIME: 1.5 Hrs.
DEALER CODING
BASIC PART NO.: 2200
CONDITION CODE: D4
07/11/05
FORD:
MERCURY:
2005 Mariner
ISSUE
ACTION
Parts Block
OPERATION: 051308A
TIME: 1.5 Hrs.
DEALER CODING
CONDITION CODE: D4
