TSB 07-3-4
02/19/07
HESITATION, MISS, ANTI-THEFT LAMP ON - DTC
B1601
FORD:
2005 Escape
MERCURY:
2005 Mariner
ISSUE
Some 2005 Escape and Mariner vehicles equipped with a 3.0L engine, may exhibit an intermittent concern of a hesitation or miss accompanied by the anti-theft lamp illuminating and diagnostic trouble code (DTC) B1601. This may be due to the spark plugs causing radio frequency (RF) interference with the powertrain control module (PCM).
ACTION
SERVICE PROCEDURE
1. Perform key on engine off (KOEO) self test.
2. If the only DTC present is B1601 (INCORRECT KEY CODE FROM IGNITION KEY TRANSPONDER) replace all six (6) spark plugs.
3. If any other DTC is present, the B1601 should be ignored and the other DTCs should be resolved first by following normal diagnostic procedures.
Parts Block
OTHER APPLICABLE ARTICLES: 05-11-01
IMPORTANT:
Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
DEALER CODING
02/19/07
B1601
FORD:
2005 Escape
MERCURY:
2005 Mariner
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
PART NUMBER | PART NAME |
AGSF-32W-M1 | SPARK PLUG |
IMPORTANT:
070304A | 2005 Escape/Mariner 3.0L: Check For DTCs, Replace All Six Spark Plugs (Do Not Use With 12650D, 12405A, 9424A) | 2.0 Hrs. |
12405 | D4 |
