Article No.
04-4-3
03/08/04
ENGINE - OIL LEAK FROM DIPSTICK OR FRONT OR
REAR CRANKSHAFT SEALS - HEATED PCV SERVICE
KIT - 3.0L DURATEC ENGINE
FORD:
2005 ESCAPE
ISSUE
Some 2005 Escape vehicles may exhibit engine oil leaking from the dipstick tube or the front or rear crankshaft seals. This condition is likely due to positive crankcase ventilation (PCV) freezing when the ambient temperature is below -30° C (-20° F), allowing engine oil pressure to build up.
ACTION
Perform oil leak diagnostics as outlined in Workshop Manual Section 303-00. With a blacklight, inspect for leaks at the oil dipstick tube and at the front and rear crank seals. If leaks are verified, order and install Heated PCV Kit number 5L8Z-6A666-AA. Replace PCV components as directed per the instruction sheet included in the Kit.
Parts Block
5L8Z-6A666-AA - Heated PCV Kit
OPERATION: 040403A
DESCRIPTION: Install Heated PCV Kit (Includes Time To Perform Engine Oil Leak Diagnostics As Outlined In Workshop Manual Section 303-00)
TIME: 0.8 Hr.
DEALER CODING
BASIC PART NO.: 6A666
CONDITION CODE: 42
04-4-3
03/08/04
FORD:
2005 ESCAPE
ISSUE
ACTION
Parts Block
OPERATION: 040403A
TIME: 0.8 Hr.
DEALER CODING
CONDITION CODE: 42
