I need to install a trans cooler for towing a small trailer approx 700miles one way and want to be safe....I have not put one on in years anyone have any experience with these and where to get one....Any suggestions???
The "axillary" transmission cooler you are referring to only comes with the V6 and Trailer Towing Package.Squishy said:You should already have one. Look at the lower grille opening (where the three small openings are). Directly behind it, you should see a small radiator with an input and output hose on the driver's side. The height of that radiator should be roughly the same as the lower grille openings.
Did they change to that in '05 or something? My '03 does not have the towing package and it has the cooler. It is definitely not a power steering cooler, either, because I have changed my transmission fluid through those lines and that is where I installed my transmission fluid filter. I don't think I have ever seen an Escape without the transmission fluid cooler.theoldwizard1 said:The "axillary" transmission cooler you are referring to only comes with the V6 and Trailer Towing Package.Squishy said:You should already have one. Look at the lower grille opening (where the three small openings are). Directly behind it, you should see a small radiator with an input and output hose on the driver's side. The height of that radiator should be roughly the same as the lower grille openings.
Shop online (eBay), sometimes you can find a genuine Ford cooler for not much money. They are easy to install. Any good auto parts store should ATF hose, but you can probably use high pressure fuel hose in a pinch.
