TSB 05-8-5
05/02/05
ABS AND BRAKE WARNING LAMP ON WITH DTC
C1526 - DTC C1524 MAY ALSO BE PRESENT -
VEHICLES BUILT PRIOR TO 2/11/2005
FORD:
2005 Escape Hybrid
ISSUE
Some 2005 Escape Hybrid vehicles built prior to 2/11/2005, may exhibit the yellow ABS and the red brake warning lamps illuminating after the engine is started, and an increase in brake pedal effort. Diagnostic trouble code (DTC) C1526 (Brake Pedal Travel Sensor) will be present in the ABS module, C1524 (Brake Pedal Travel Sensor Calibration Incomplete) may also be present.
ACTION
Install a revised master cylinder. Refer to Workshop Manual Section 206-06.
5M6Z-2140-B - Master Cylinder
OPERATION: 050805A
DESCRIPTION: 2005 Escape Hybrid Replace Master Cylinder (Do Not Use With 12650D, 2140A, 12651D70, 2000A)
TIME: 1.6 Hrs.
DEALER CODING
BASIC PART NO.: 2140
CONDITION CODE: 42
05/02/05
FORD:
2005 Escape Hybrid
ISSUE
ACTION
OPERATION: 050805A
TIME: 1.6 Hrs.
DEALER CODING
CONDITION CODE: 42
