1 - 2 of 2 Posts
TSB 06-20-12
10/16/06
SQUEAK / CREAK NOISE FROM REAR - VEHICLES
BUILT BEFORE 9/5/2006
FORD:
2006-2007 Escape Hybrid, Escape
MERCURY:
2006-2007 Mariner Hybrid, Mariner
ISSUE
Some 2006-2007 Escape, Mariner, Escape Hybrid and Mariner Hybrid vehicles built before 9/5/2006 may exhibit a high pitched squeaking noise from the rear upper shock bushing area. This concern is more noticeable while driving over small cracks or bumps during parking lot maneuvers. This may be caused by the upper shock bushing coming out of position causing the shock rod to contact the body.
ACTION
Follow the Service Procedure steps to correct the condition by replacing the shock bushing.
NOTE
IT IS NOT NECESSARY TO REPLACE THE SHOCK ASSEMBLY.
SERVICE PROCEDURE
Verify noise is present by bouncing the parked vehicle from the rear and listening to the rear shock area. If inaudible, drive the vehicle and listen to the rear shock area during parking lot maneuvers over small bumps. If noise is determined to be from the upper rear shock area, continue with repair procedure.
1. Remove rear quarter trim panels to expose the upper shock bushing.
2. Remove upper shock rod nuts, washer and bushing.
3. Pull down on shock rod from the outside of the vehicle to remove the lower bushing and provide clearance for drilling the bushing hole.
4. Using a step drill bit (preferably one that stops at 7/8" or 22 mm) and drilling from inside the rear of the vehicle from the top down enlarge the mounting hole to 7/8" (22 mm). (Figure 1) Drill bits may be obtained from the Rotunda Technician Tool Program (RTTP) tool number VGP161O4 or a local tool supplier.
5. De-burr the newly drilled hole and coat with Motorcraft® Low Temperature Anti-Corrosion Coating, PM-12-A.
NOTE
USE OF PM-12-A FOR THE ENLARGED HOLE IS ESSENTIAL TO PREVENT CORROSION IN THIS CRITICAL AREA EXPOSED TO MOISTURE AND ROAD SALT.
6. Install new lower half of the upper bushing and washer onto shock rod. (Figure 2)
7. Guide the shock rod and bushing through the hole and verity that the bushing is completely through the hole. (Figure 3)
8. Install upper bushing / washer nut and torque to 29 lb-ft (40 N.m).
NOTE
IT MAY BE NECESSARY TO HOLD THE TOP OF SHOCK ROD DURING TORQUE OPERATION TO ELIMINATE ROTATION OF
SHOCK ROD.
NOTE
BUSHING WILL BE NOTICEABLY COMPRESSED MORE THAN THE STOCK BUSHING. (FIGURE 4)
9. Repeat procedure for the other side.
10. Reinstall the rear trim panels.
Parts Block
PART NUMBER
PART NAME
7L8Z-18198-AShock Assembly Mounting
PM-12-AMotorcraft Low Temperature Anti-Corrosion Coating
OPERATION
DESCRIPTION
TIME
062012A2006-2007 Escape, Mariner, Escape Hybrid, Mariner Hybrid: Replace The Upper Shock Bushings Following Service Procedure (Do Not Use With 18125A, 31012A)
1.0 Hr.​
DEALER CODING
BASIC PART NO.
CONDITION CODE
18008
07​
Discussion Starter · #2 ·
TSB: 02-002/07
2006 TRIBUTE - SQUEAK / CREAK NOISE FROM REAR OF VEHICLE
APPLICABLE MODEL(S)/VINS
2006 Tribute vehicles produced before September 5, 2006
DESCRIPTION
Some vehicles may exhibit a high pitched squeaking noise from the left and/or right rear upper shock bushing area. This concern is more noticeable while driving over small cracks or bumps during parking lot maneuvers. This may be caused by the upper shock bushing coming out of position causing the shock rod to contact the body.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Verify noise is present by bouncing parked vehicle from rear and listening to rear shock area. If inaudible, drive vehicle and listen to rear shock area during parking lot maneuvers over small bumps. If noise is determined to be from the left or right upper rear shock area, continue with repair procedure.
NOTE:
It is NOT necessary to replace the shock assembly.
2. Remove rear quarter trim panels to expose upper shock bushing according to Workshop Manual (section 09-17 INTERIOR TRIM PANELS).
3. Remove upper shock rod nuts, washer and bushing.
4. Pull down on shock rod from outside of vehicle to remove lower bushing and provide clearance for drilling bushing hole.
5. Using a step drill bit (preferably one that stops at 7/8" or 22 mm) and drilling from inside rear of vehicle from top down, enlarge mounting hole to 7/8" (22 mm). Drill bits may be obtained from a local tool supplier.
6. De-burr newly drilled bolt hole and coat with Low Temperature Anti-Corrosion Coating.
NOTE:
Use of anti-corrosion coating for enlarged hole is essential to prevent corrosion in this critical area exposed to moisture and road salt.
7. Install new lower half of upper bushing and washer onto shock rod.
8. Guide shock rod and bushing through hole and verify that bushing is completely through hole.
9. Install upper bushing / washer nut and torque to 29 lb-ft (40 N.m).
NOTE:
^ It may be necessary to hold the top of shock rod during torque operation to eliminate rotation of shock rod.
^ Bushing will be noticeably compressed more than stock bushing.
10. Repeat procedure for other side if noise is present.
11. Reinstall rear trim panels.
12. Verify repair.
PART(S) INFORMATION
Part Number
Description
Qty.
Notes
ZZC0-28-807​
Shock Assembly Mounting​
1​
0000-77-601E-01​
Low Temperature Anti-Corrosion Coating​
1​
Order through Mazda Chemicals Program​
WARRANTY INFORMATION
Warranty Type
A​
Symptom Code
82​
Damage Code
9H​
Part Number Main Cause
ZZC0-28-807​
Quantity
1​
Operation Number / Labor Hours:
YY456XR1 / 1.2 Hrs (one side)
YY456XR2 / 2.4 Hrs (both sides)​
NOTE:
^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
^ Additional diagnostic time cannot be claimed for this repair.
1 - 2 of 2 Posts
