TSB 06-6-7
04/03/06
TURN SIGNALS - RAPID FLASHING
FORD:
2006 Escape
MERCURY:
2006 Mariner
ISSUE
Some 2006 Escape and Mariner vehicles built between 10/3/2005 and 11/2/2005 equipped with fender-mounted side turn signal lamps may experience "fast flashing" (which normally indicates a burned out bulb) of either the left, right, or both turn signals even though a turn signal lamp is not burned out. In some cases this "fast flashing" is immediately noticeable when the turn signal is activated. In other cases, the bulb will flash normally for quite some time before flashing at the faster rate.
The cause of this issue is an improperly set current threshold within the smart junction box (SJB) associated with the addition of side markers. The threshold was set too close to the normal operating range which in some cases means that the SJB senses less current than expected thereby fast flashing the turn signals.
ACTION
Use the following Service Procedure to alter the programmable settings for the SJB using the Worldwide Diagnostic System (WDS) release B42.0 or higher to change the "Turn Signal Side Markers" customer preference from "Equipped" to "Not Equipped". This will not affect the proper operation of the Turn Signal Side Markers but will force the SJB to use a different threshold value that does not exhibit the "Fast Flash" issue.
SERVICE PROCEDURE
1. Connect the WDS to the vehicle and follow all screens until the vehicle is identified and the WDS is at the main menu.
2. Select "Toolbox".
3. Select "Module Programming".
4. Select "Programmable Parameters".
5. Select "Exterior Lighting".
6. Select "Turn Signal Side Markers". The current setting will normally be shown as "Equipped".
7. Select the "Not Equipped" option.
8. After the preference has been successfully changed, verify that the Fast Flash Turn Signal issue has been corrected.
DEALER CODING
04/03/06
FORD:
2006 Escape
MERCURY:
2006 Mariner
ISSUE
ACTION
SERVICE PROCEDURE
MT060607 | Claim Labor As Actual Time | Actual Time |
15604 | 04 |
