1 - 2 of 2 Posts
TSB 05-22-13
11/14/05
WINDSHIELD WASHER INOPERATIVE - HOSE
DISCONNECTED
FORD:
2006 Escape
ISSUE
Some 2006 Escapes built from 8/1/2005 through 9/30/2005 may exhibit an inoperative windshield washer and/or windshield washer fluid leaks when activated. This is most likely due to a washer hose that has become disconnected.
ACTION
Replace the hose if it has become disconnected. The suspect hose is located just above the right (passenger) side front fender splash shield. To replace the hose, remove the right side inner fender splash shield following Workshop Manual Section 501-02.
Parts Block
PART NUMBER
PART NAME
YL8Z-17408-AAWindshield Washer Hose
OPERATION
DESCRIPTION
TIME
052213AReplace Windshield Washer Hose Includes Time To Remove and Install Splash Shield (Do not use with 17664A, 17618A, 16102A)
0.6 Hr.​
DEALER CODING
BASIC PART NO.
CONDITION CODE
17408
D4​
OASIS CODES: 202000
Discussion Starter · #2 ·
TSB: 09-016/06
2006 TRIBUTE - WINDSHIELD WASHER INOPERATIVE - HOSE DISCONNECTED
APPLICABLE MODEL(S)/VINS
2006 Tribute vehicles built from 8/12/2005 through 9/30/2005
DESCRIPTION
Some vehicles may exhibit an inoperative front or rear windshield washer and/or windshield washer fluid leaks when activated. This is most likely due to a washer hose that has become disconnected.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Verify concern.
2. safely lift vehicle on hoist.
3. Remove right front wheel and tire assembly.
4. Remove right front fender splash shield.
5. Inspect windshield washer hoses located above splash shield.
6. If either hose has become disconnected, replace it with a modified part.
7. Verify repair.
PART(S) INFORMATION
Part Number
Description
Qty.
EC05-67-500D​
Windshield Washer Hose​
1​
WARRANTY INFORMATION
Warranty Type
A​
Symptom Code
91​
Damage Code
9H​
Part Number Main Cause
EC05-67-500D​
Quantity
1​
Operation Number / Labor Hours:
YY418XRX / 0.6 Hrs.​
NOTE:
^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
^ Additional diagnostic time cannot be claimed for this repair.
1 - 2 of 2 Posts
