hi
ive had my escape for about 2 months well i finally had a full car the other day and for the life of me and the boys we couldnt work out how to make the middle seat belt work. its sorta got a belt that comes down from the boot area to the middle and plugs in to the plug into bit then thats it, sort of hard to explain but its like im missing a bit.
any one else with a 2006 zc thats has this problem or knows whats missing
cheers
Did the bit your missing slide down the belt into the under seat area? Could be you need to lift the seat and see if it got caught underneath the seat when it was flipped up and then down again. Just out of site. At least it should be there, no way to get it off the belt without cutting the belt, or removeing the bolted tiedown... :confused:
well i have worked out what is missing, its the actuall clip on the retractable bit that u then pull across ur waist.
how its not there i have no idea but look like in off to ford
cheers
