NOTE: Escape shown, Mariner similar.
Item - Part Number - Description
1 - Sail panel
2 - Door handle finish panel
3 - Door handle screw
4 - W505004 - Door inside handle screw
5 - W505004 - Front door trim panel screw (3 required)
6 - 14631 - LH power window electrical connectors
7 - Door handle
8 - 23942 RH / 23943 LH - Front door trim panel
Removal and Installation
NOTE: LH side shown, RH side similar.
1) Remove the door sail panel.
* If equipped, disconnect the power mirror electrical connector.
2) Open and remove the door handle finish panel.
* Pull the door handle outward to fully access the door handle finish panel.
3) Remove the door handle screw.
4) Remove the door inside handle screw.
5) Remove the 3 door trim panel screws.
6) Remove the door trim panel.
* Pull outward and then upward on the door trim panel.
* Disconnect the electrical connectors.
7) Remove the door handle from the door trim panel.
* Disconnect the electrical connector.
* Press the 2 retaining tabs while pushing the door handle from the door trim panel.
* Remove the door handle from the door trim panel by pulling it back through the door trim panel.
8) To install, reverse the removal procedure.
1 - Sail panel
7 - Door handle
