Hope all here have been well. MtmnEscaped that I've owned for 11 wonderful years now has me stumped, (intermittent check engine light-no codes stored for an issue that been going on for a few days now-more or less parked for that time troubleshooting).
It has just over 154,000 miles / all fluids maintained and clean / only minor repairs to the engine / with one oil leak now toward the front of the engine, (believe it's the timing cover but not really bad yet).
So,
the other day with no warning it started "stumbling" as 55-60 MPH-yet it was not, (and still is not constant). Very first thing I suspected was bad gas so I dumped a can of HEET into the 3/4 full tank of regular unleaded. Ran it another 40-50 miles and then another 10 minutes at high RPN after getting home, (engine miss still there still intermittent). I found a live data code with my scanner indicating possibl #5-cylinder misfire, (no laptop for Forscan). so, I replaced the plug and coil on #5 and nothing changed, (note the plug I pulled from there has to be original and the gap was way up near .80 instead of .51-.54 as recommended). No change the miss is still there...
So Wednesday I go for some Berryman B-12 fuel injector cleaner and added to the gas tank then topped off the tank to full with 5 gallons of ethanol free fuel. Ran another 20-30 minutes since then at above average RPM, (holding it as close to 4K as possible without the miss happening).
Symptoms: the engine miss is mostly happening over 4000 RPM / I tried yesterday to hold the pedal to the floor and the engine will not go over 4250 or so (does the ECM have a rev limiter-it should still be higher than that correct if it does have one?
If the throttle body were malfunctioning, would it do this-or would that miss be constant and also pop a code?
If it were a burnt valve that too would be constant correct, would there be a code?
Please help/limited income/brain tumor / and now non-Hodgkins follicular cancer and this is my one and only ride to the VA Dr with no one to fall back on.
So,
