When I put my new speakers in, it took me a while to figure this out so I figured I would maybe help some people out. Now other than the screws that are on the outer edge of the door panel holding it to the door, and the screw in the handle part of the part that houses the window switches etc., there is one other little trick. Behind the door handle from the inside there is a little plastic panel. What you need to do is get a small flat head screw driver and there is a little open slot where u can put the tip of the screw driver in and pop that little panel out. There is now a screw there that needs to be taken out. You than just pull the door panel but dont yank to hard because just like every other door panel, there are small clips that it clips to. Removal is very simple and takes only a matter of minutes to do. Just an fyi, if I missed anything feel free to add on as I have already done this and just going off memory.
