1 - 3 of 3 Posts
Discussion Starter #1
TSB: 01-038/07
2008 TRIBUTE 3.0L - ENGINE GRINDING/RATTLING NOISE AT IDLE
APPLICABLE MODEL(S)/VINS
2008 Tribute 3.0L
DESCRIPTION
Some vehicles may exhibit a grinding or rattling noise while the engine is running. The noise is most noticeable at idle.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Verify customer concern.
2. Verify vehicle build date.
3. Record customer's preset radio stations.
4. Remove starter according to Workshop Manual (section 01-19 STARTER MOTOR - 3.0L REMOVAL AND INSTALLATION).
5. Inspect starter drive for loose washers and/or snap ring not seated in shaft groove. If found, replace starter according to Workshop Manual (section 01-19 STARTER MOTOR - 3.0L REMOVAL AND INSTALLATION).
6. Re-enter customer's preset radio stations.
7. Verify repair.
PART(S) INFORMATION
Part Number
Description
Qty.
AJC8-18-400A​
Starter​
1​
WARRANTY INFORMATION
Warranty Type
A​
Symptom Code
82​
Damage Code
9M​
Part Number Main Cause
AJC8-18-400A​
Quantity
1​
Operation Number / Labor Hours:
YY486XRX / 0.6 Hrs​
Discussion Starter #2
Bulletin No.: 05-006/08
Last Issued: 05/08/2008
Subject:
CD4E AUTOMATIC TRANSMISSION - FLUID LEAK FROM TRANSMISSION COOLER
APPLICABLE MODEL(S)/VINs
2008 Tribute vehicles equipped with a CD4E automatic transmission built before Feb. 18, 2008
(Service Bulletin is not applicable to Tribute Hybrid)
DESCRIPTION
Some vehicles may exhibit a fluid leak from the transmission cooler. Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
NOTE:
PERFORMING THIS SERVICE BULLETIN WILL PREVENT REPEAT TRANSMISSION FLUID COOLER FAILURE. THE UPDATED SERVICE BOLT ELIMINATES STRESS ON THE COOLER FROM THERMAL EXPANSION.
2. Remove the transmission cooler/A/C condenser according to the Workshop Manual (section 07-11 CONDENSER CORE REMOVAL/INSTALLATION).
NOTE:
The transmission cooler is part of the A/C condenser assembly and cannot be serviced separately.
3. When installing the new transmission cooler, install the updated service bolt on the passenger side of the cooler, opposite the inlet and outlet cooler tubes.
Tightening Torque: 55 lb-in (6.2 Nm)
CAUTION:
USING ANY BOLT OTHER THAN THE UPDATED SERVICE BOLT MAY CAUSE TRANSMISSION FLUID COOLER ASSEMBLY FAILURE.
4. Install the transmission cooler/A/C condenser according to the Workshop Manual (section 07-11 CONDENSER CORE REMOVAL/INSTALLATION).
5. Install the driver side transmission fluid cooler/A/C condenser bolt.
Tightening Torque: 62 lb-in (8 Nm)
6. Verify repair.
PART(S) INFORMATION
Part Number
Description
Qty.
ZZC2-61-480A​
Transmission / A/C Cooler​
1​
ZZCA-19-233​
Bolt​
1​
NOTE:
^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair.
^ This repair will be covered under Mazda's New Vehicle Limited Warranty term.
^ Additional diagnostic time cannot be claimed for this repair.
Warranty Type
A​
Symptom Code
76​
Damage Code
9A​
ZZC2-61-480A​
Quantity
1​
YY518XRX / 1.1 Hrs (includes bumper cover removal/installation, evacuation and charging A/C system, and top off ATF)​
1 - 3 of 3 Posts
