1 - 2 of 2 Posts
TSB 07-26-5
12/24/07
BLOWER MOTOR INOPERATIVE OR STUCK ON HIGH
FORD:
2008 Escape Hybrid, Escape, F-Super Duty
MERCURY:
2008 Mariner Hybrid, Mariner
ISSUE
Some 2008 F-Super Duty vehicles built before 12/14/2007, Escape, Mariner, Escape Hybrid and Mariner Hybrid vehicles built before 12/17/2007 and equipped with electronic automatic temperature control (EATC) may exhibit an inoperative blower motor or a blower motor that may also shift to and remain at high, low or off speed. Cycling the ignition may return normal operation. The concern may also occur when using the electrical power point.
ACTION
Replace the Blower Motor Speed Control per Workshop Manual, Section 412-01.
Parts Block
PART NUMBER
PART NAME
7C3Z-19E624-CBlower Motor Control
OPERATION
DESCRIPTION
TIME
072605A2008 F-Super Duty/Escape/Escape Hybrid/Mariner/Mariner Hybrid With EATC: Replace The Blower Motor Speed Control (Do Not Use With 19700D, 19700D8)
0.3 Hr.​
DEALER CODING
BASIC PART NO.
CONDITION CODE
19E624
42​
Discussion Starter · #2 ·
Bulletin No.: 07-002/08
Last Issued: 2/25/2008
Subject:
HYBRID - BLOWER MOTOR INOP OR STUCK ON LOW OR HI
APPLICABLE MODEL(S)/VINs
2008 Tribute Hybrid vehicles built before 12/17/2007
DESCRIPTION
Some Tribute Hybrid vehicles built before 12/17/2007 and equipped with electronic automatic temperature control (EATC) may exhibit an inoperative blower motor or a blower motor that may also shift to and remain at high, low or off speed. Cycling the ignition may return normal operation. The concern may also occur when using the electrical power point.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Verify customer concern.
2. Replace the Blower Motor Control (resistor) with a modified one.
a. Lower the glove compartment.
b. Disconnect the blower motor control connector (1).
c. Remove fasteners (2) attaching blower motor control to HVAC assembly.
d. Remove the blower motor control (3).
e. To install, reverse removal procedure.
3. Verify repair.
PART(S) INFORMATION
Part Number
Description
Qty.
ZZCB-61-815​
Blower motor control (resistor)​
1​
WARRANTY INFORMATION
NOTE:
^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
^ Additional diagnostic time cannot be claimed for this repair.
Warranty Type
A​
Symptom Code
61​
Damage Code
9B​
Part Number Main Cause
ZZCB-61-815​
Quantity
1​
Operation Number / Labor Hours:
YY501XRX / 0.3 hr​
1 - 2 of 2 Posts
