Hello all, I keep coming across this site when finding useful information regarding my 2008 Escape Hybrid so I figured I would post about an issue that has absolutely stumped me.
From looking at this site and the Mitchell repair data information, I performed the EATC test with the POWER and DEFROST buttons with FLOOR button to run the On-Demand Self Test for the EATC. It constantly displays the following codes:
86 E0 - with the Fahrenheit symbol
8F 08
00 05
I cannot find any reference to any of these codes anywhere. I assume that the letter B is appended to the beginning to insinuate a Body Control Module fault, such as B86E0 but that's not getting me anywhere either.
A bit of history on this Escape is that we got it and are just now testing out the A/C. It was hard to test when we got it in the winter, but at least it moves the airflow to all vents. It looks like this Escape had some front end damage, the fenders are held in with a couple extra sheet metal screws and it wasn't until recently that I discovered that the dang cooling fan resistor was unplugged! Now the cooling fans come on when I request A/C and I occasionally hear the pump kick in (RPM change) but it's never spinning when I look under the hood. Unrelated but the MECS pump was dangling from the fan shroud so I think someone's been in the front end before, possibly due to the front end damage. But, the system is charged. I hooked up one of those cheap top-off/recharge cans and the little gauge on it said about 32PSI, I took it up closer to 40PSI but no change in the situation. After running the above On-Demand Self Test, I did clear the codes, waited 30 seconds and turned the Ignition off. I then turned Ignition back on and ran the test again and the codes came back immediately. I'm thinking these codes are immediate electrical failures (something else unplugged, faulty sensor, etc...) but I don't know what direction to go from here. Any help would be greatly appreciated. Thanks.
8F 08
00 05
