A P1000 is not an issue. This is a normal code to let you know the monitors have not been completed.Also, I guess that the presence of a permanent P1000 is an issue in itself and that should be mentioned/investigated by the garage too.
Good idea to take the vehicle to a repair shop. You have to have the check engine light on, or codes in the modules, for them to figure it out. So, drive the vehicle till it trips some codes and do not clear them. I would not offer them any tips for diagnostics. They know what they are doing. Just state the facts, loss of performance when warm.Ohh ok so this P0685 error should be pursued, gotchya! So I'll get the plugs and boots and the back-pressure test done regardless and also ask them to load test -specifically- the circuit related to that error too. Reading wiring diagrams and doing the DC load tests might be a little out of my league to do myself but I'll see if I can find a decent video as I'm a complete novice and I need to see someone do exactly what I'm going to be doing. I think I have one of those lightbulbs that attaches to the battery ..I guess those croc clips might be too big. I did give that relay a tap like you said btw, Dwight...I read somewhere else that people would switch out relays to see if the issue followed the relay - wondered whether that might be worth doing.
Considering it's booked in on Friday and I'm workin' all week - I think I'll leave it to Midas - I just need to be super clear with them what I want them to do. I'm liable to miss something and kick myself when I jump back on here! I guess I need to get them to try to reproduce the P0685 and load test that circuit first and foremost. The carfax report that I have for the history of this vehicle makes mention of regular oil and filter changes but nothing about plugs so I guess that says it all. Plugs, boots, tune-up and P0685 load testing/test all grounds?
Humbled by all this support. Onward!
Thanks!
Cam
You know, just offhand… It almost sounds like your catalytic converter is plugged up. runs good cold, but when it heats up it becomes sluggish…Thank you! Yes, whole-heartedly agreed and hoped. I've been spending my spare time doing some more tests on the battery (which checks out ok even though it's older). I found the source of the chirping sound when the A/C comes on (A/C clutch I think). I've used Forscan to test the rear fans and thankfully they are both working! No rear actuator door faults and the filter is new. I took the cover off so I can see the air vents and it's clean in there too.
It's gotta be the A/C as you say and that is my next move. It weirds me out that it's not throwing codes related to heat degrading performance. I mean, if the battery isn't cool enough and performance will be degraded (noticably) until it gets to the optimal temperature - throw me a CEL or something maybe eh? That seems to be a bit of a design oversight, to me. Everything does seem to point to the A/C though. One of the pipes at the back is cold but not freezing cold when it's running and the meat thermometer that I have in the vent isn't getting much lower than 60 degrees Fahrenheit. The A/C is working - but not well enough, it seems!
Thanks again. Will report back - should be getting the A/C sorted on Friday.
Thanks for reading all this and thanks for your feedback.. so much has happened that I may have neglected to update that part! I went to a muffler place and they performed such a test...they disconnected the cat and O2 sensor to test it (it ran really noisily while that test was done, of course) They let me drive it too and I didn't feel any difference. They were a little baffled and, not being familiar with the FEHs, suggested that it's normal as it's "just a 4-banger". I'm not expecting anything fantastic, performance-wise and the fuel economy is outstanding. It really is sluggish though and often a real struggle to drive. Seems inhibited by something. In the back of my mind I'm wondering whether this A/C thing is going to be the solution or not but I've had mini-breakthroughs before and ended up being disappointed so I'm kinda used to it.You know, just offhand… It almost sounds like your catalytic converter is plugged up. runs good cold, but when it heats up it becomes sluggish…
They are not cheap to replace, so I would not recommend just throwing a new one at it. I have never seen a test that shows exhaust flow levels… manifold back pressure tester?
But may be your local muffler shop could do something like that?
The only thing I know to test it is to cut it out of your exhaust pipe(leaving enough exposed pipe to re-weld it back in), and sleeve in a piece of straight pipe for a test drive.
PS - I do feel the exhaust fumes coming from the tail pipe if I put my hand over it ..I gather that if the cat was clogged, I wouldn't be feeling much, if anything. I've put some of that cat cleaner through the fuel system too.Thanks for reading all this and thanks for your feedback.. so much has happened that I may have neglected to update that part! I went to a muffler place and they performed such a test...they disconnected the cat and O2 sensor to test it (it ran really noisily while that test was done, of course) They let me drive it too and I didn't feel any difference. They were a little baffled and, not being familiar with the FEHs, suggested that it's normal as it's "just a 4-banger". I'm not expecting anything fantastic, performance-wise and the fuel economy is outstanding. It really is sluggish though and often a real struggle to drive. Seems inhibited by something. In the back of my mind I'm wondering whether this A/C thing is going to be the solution or not but I've had mini-breakthroughs before and ended up being disappointed so I'm kinda used to it.
I don't know much (well, anything really!) about the catalytic converter system on this truck but aren't there a few cats? Is there a chance that they just didn't know that and that there was another one that should have been disconnected for the test?
One more thing I'll add here is that I'll be replacing the front driver side vent-selector actuator this week as that has been clicking since I got this vehicle. I don't think that has any bearing on this case as I understand the cooling system for the batt is separate from the cabin system. Just in the interest of full-disclosure.
If anyone wants me to grab some specific Forscan data from the truck - I can do that also.
An appreciative,
Cam
Just trying to cover all the bases ( :PS - I do feel the exhaust fumes coming from the tail pipe if I put my hand over it ..I gather that if the cat was clogged, I wouldn't be feeling much, if anything. I've put some of that cat cleaner through the fuel system too.
