The power steering on our 2008 Ford Escape has failed and is essentially operates like a manual steering vehicle. After research, we diagnosed the problem as a failed Electric Power Assisted Steering (EPAS) module, bought one from a salvage yard and swapped it out with not change to the symptoms.
I am looking for help in two areas: 1) determining if there is a way to "bench test" the old module to see if was even bad in the first place and 2) identifying any other potential failed components to look at.
Details on symptoms and testing below.
I have seen other threads for 2008 Escape Hybrids discussing a Power Steering Control Module. Can't tell if this is a hybrid only component or another potential root cause for the power steering problem.
Does anyone know if I should be able to see an amperage draw in the engine compartment across the 80A fuse with an ammeter when the steering wheel is turned if the EPAS is functional? This might be a way to assess if the replacement part currently installed is failed as well.
Appreciate any suggestions or advice to identify and resolve the problem. I'm about to get another 80A fuse and replace in on the off chance that it is partially failed, but am otherwise out of ideas except to swap out the EPAS again.
Alan
- Vehicle's power steering suddenly stopped working, no specific incident (according to my son) that caused it to change
- No on-board diagnostic error codes of any kind (ODB II read, only a misfire code present)
- Power detected at what I assess to be the supply connection (orange body for connector, forward-most of the three on the left side of the EPAS module. Strangely, I previously had a good voltage test at the 80A fuse in the engine compartment fuse box, but wasn't able to get readings across it after I swapped out the EPAS and reaccomplished earlier troubleshooting tasks.
- Replacement EPAS was off of a Ford Mariner and process was challenging, but uneventful. I don't think the seller did any testing of the part and know it was pulled from a vehicle in the junkyard which did not appear to have had indications of front end or right side collision.
Alan
