1 - 1 of 1 Posts
SEAT CUSHION-REAR, SUPERCAB
Removal and Installation
1. NOTE: 60 percent seat shown, 40 percent seat similar.
Remove the seat.
2. Remove the bolts.
a. Remove the upper bolt.
- To install, tighten to 33 Nm (24 lb-ft).
b. Remove the lower bolt.
- To install, tighten to 25 Nm (18 lb-ft).
3. Remove latch shield and the bolt.
- To install, tighten to 50 Nm (37 lb-ft).
4. Separate the seat cushion from the center seat mount.
5. To install, reverse the removal procedure.
SEAT CUSHION-REAR, 60/40, CREWCAB
1. Remove the 60/40 percent rear seat.
2. Remove the 2 bolts from the back side of center support.
3. Separate the 40 percent seat and the 60 percent seat from the center support.
4. Remove the screw and the side latch shield.
5. Remove the screw and the cushion release handle.
6. Pry the side shield to release the 3 clips and remove the side shield.
7. Remove the 2 bolts and remove the cushion assembly.
8. Remove the bolt and remove the seat cushion latch assembly.
9. To install, reverse the removal procedure.
1 - 1 of 1 Posts
