1 - 2 of 2 Posts
Direct image link: http://i246.photobucket.com/albums/gg10 ... luster.jpg
Instrument Cluster (IC)
Item - Part Number - Description
1 - 78044D70 - Instrument cluster (IC) finish panel
2 - W713306 - Instrument cluster (IC) screws (4 required)
3 - 10849 - Instrument cluster (IC)
Removal
1. If installing a new instrument cluster (IC), upload the module configuration information to the scan tool.
2. Lower the tilt steering column to the lowest position.
3. Pull the instrument cluster (IC) finish panel straight out to release the retainer clips and remove the finish panel.
* Disconnect the instrument panel dimmer switch electrical connector and the ambient air temperature sensor (if equipped).
4. Remove the 4 instrument cluster (IC) screws and the instrument cluster (IC).
* Disconnect the electrical connector.
Installation
1. Position the instrument cluster (IC), connect the electrical connector and install the 4 instrument cluster (IC) screws.
2. Position the instrument cluster (IC) finish panel, connect the instrument panel dimmer switch electrical connector, the ambient air temperature sensor (if equipped) and install the finish panel.
3. If installing a new instrument cluster (IC), download the instrument cluster (IC) configuration information from the scan tool into the new instrument cluster (IC).
4. NOTE: If a new instrument cluster (IC) is installed, the instrument cluster (IC) and the PCM require a parameter reset to allow the instrument cluster (IC) and the PCM to recognize each other. Failure to carry out the parameter reset to the instrument cluster (IC) and the PCM may result in a no start condition.
NOTE: If equipped, the vehicles passive anti-theft system (PATS) keys must be programmed to the new instrument cluster (IC).
* If installing a new instrument cluster (IC), carry out the parameter reset and key programming procedure.
Help... Does anyone know if I can Chang from the IC from my XLS to the one from The XLT?
I want to add the this computer functions to my 2009 escape.
I have the button and can get the IC from an XLT on eBay.
Will this work?
Thanks
Joe
1 - 2 of 2 Posts
