1 - 2 of 2 Posts
I recently installed HIDs for my low beams. I installed it with a relay harness, using the low beam socket as the trigger for the relay.
I'm currently having problems because when I flash with my high beams when my low beams are off, the low beams would turn on as well because as we know, the escape uses the low beam circuitry for the high beam indicator.
I was planning to change my wiring in such a way that:
My headlight switch triggers the relay directly. This would mean that the low beams won't turn on with the high beams and the low beams remain on when I turn on the high beams at night.
I'll be putting relays on the lowbeam sockets to retain functionality of the highbeam indicator.
I'm basically looking for a way to trigger my relay harness when I put my headlamp switch into position 3. Any and all help will be appreciated. Thanks!
1 - 2 of 2 Posts
