1 - 1 of 1 Posts
Direct image link: http://i246.photobucket.com/albums/gg10 ... ooract.jpg
Item - (Part Number) - Description
1 - (part of 19D887) - Air inlet mode door actuator electrical connector
2 - (W701696) - Air inlet mode door actuator screw (2 required)
3 - (19E616) - Air inlet mode door actuator
Removal and Installation
1. Remove the heater core and evaporator core housing. For additional information, refer to Heater Core And Evaporator Core Housing in this section.
2. Disconnect the air inlet mode door actuator electrical connector.
3. Remove the 2 air inlet mode door actuator screws.
* To install, tighten to 3 Nm (27 lb-in).
4. Remove the air inlet mode door actuator.
5. To install, reverse the removal procedure.
1 - 1 of 1 Posts
