1 - 1 of 1 Posts
TSB 09-6-9
04/06/09
6F35 TRANSMISSION, DTC- P0770, P0772, P0773,
P0774-BUILT 9/8/2008 TO 9/26/2008 - MIL LAMP
ON - ERRATIC SHIFT AND/OR HARSH
ENGAGEMENTS
FORD:
2009 Escape
MERCURY:
2009 Mariner
ISSUE
Some 2009 Escape and Mariner vehicles equipped with a 6F35 transmission and built between 9/8/2008 and 9/26/2008 may exhibit diagnostic trouble codes (DTCs) P0770, P0772, P0773, P0774, The DTC's indicate open, short to ground or short to power in shift solenoid E (SSE) circuit. The failure modes that may be associated with the DTC's are erratic shifts, harsh engagements, 5th gear drive away, no torque converter clutch (TCC) apply, malfunction indicator lamp (MIL) on. This may be caused by a shorted circuit in the powertrain control module (PCM).
ACTION
SERVICE PROCEDURE
  1. Follow pinpoint test A - Transaxle Control Solenoids as described in Workshop Manual (WSM), Section 307-01, through test step AS - Check The Resistance Of The Solenoid Field Circuit. If Result/Action is:
    • Yes - Replace the powertrain control module (PCM), refer to WSM 303-14.[/*]
    • No - This procedure does not apply and continue with diagnostic steps.[/*]
  2. Use the IDS Programmable Module Installation (PMI) function to insure the new PCM has the transmission solenoid body strategy downloaded.[/*]
OPERATION
DESCRIPTION
TIME
090609A2009 Escape, Mariner: Replace The PCM, Includes Time To Perform Pin Point Tests And Perform PMI (Do Not Use With 12650D, 12650D6, 12650D45)
1.1 Hrs.​
DEALER CODING
BASIC PART NO.
CONDITION CODE​
12A650
28​
1 - 1 of 1 Posts
