TSB 09-6-2
04/06/09
2.5L WITH AUTOMATIC TRANSMISSION - ROUGH
IDLE IN DRIVE - COLD ENGINE
FORD:
2009 Escape
MERCURY:
2009 Mariner
ISSUE
Some 2009 Escape and Mariner vehicles built before 3/5/2009 equipped with 2.5 liter engine and 6 speed automatic transmission may exhibit a rough idle. Concern typically occurs when the engine is cold, under load (such as A/C on) and in drive. All ignition and fuel system testing pass and there are no DTCs.
ACTION
SERVICE PROCEDURE
DEALER CODING
04/06/09
FORD:
2009 Escape
MERCURY:
2009 Mariner
ISSUE
ACTION
SERVICE PROCEDURE
- Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 59.8 and higher or 60.01 and higher. Calibration files may also be obtained at the website.
[/*] - Perform the powertrain mount neutralization procedure in the Workshop Manual, Section 303-00.[/*]
090602A | 2009 Escape, Mariner 2.5L Automatic Transmission: Reprogram The PCM, Includes Time To Neutralize Powertrain Mounts (Do Not Use With 12650D) | 0.7 Hr. |
RECAL | 04 |
