Adding a mechanical switch to enable the rear diff should not cause problemrs, but it should be disabled as soon as you are on pavement or things will get damaged. The duty cycle would not be unreasonable.
Too bad there is not a switch to enable locking the rear diff, then it would be even handier.
I just don't see how locking the rear diff would transfer more power to the rear.
I don't know if you've driven a vehicle with a rear locker in the mud or the snow, but they are very tricky to handle.
I installed automatic lockers in my CJ-7 … If you forget to unlock, you wind up in a ditch.
I can't imagine they even make a locker for a tiny escape differential, if I remember right, in the rear, it is not even a differential.
I'm saying max 5 inch diameter housing, which must put the inner gears at 3 inches/od
I think these people are experiencing 'all season' tires in a winter weather situation. The difference between dedicated winter(studded), snow tires, and anything else is night and day.
putting a locker in the rear diff would eliminate the traction control computer module, and cause it to fight itself
you're not going to re-engineer your Ford escape into an Audi Quattro!
