I have a 2010 Ford Escape XLT with 95,000 miles on it...about 5 months or so ago one day it just starting to long crank before starting....(meaning when I turn the key and let go it will some times crank longer than it should before starting). It has ALWAYS started...just sometimes it cranks for maybe 4 to 7 seconds. Been to two ford dealers that can't find ANYTHING wrong. NO codes, PCM has been updated, Plugs just changed yet I still have the issue.
Doesn't matter what the temp is.
Some things I have noticed. IF I haven't driven the car in a while (say a day or two) usually it fires right up. After getting gas it always fires right up. But say I drove it work (like I did today) I can shut it off then go to start it up again and it will long crank. Again it ALWAYS starts.
I have tried turning the key to the on position to "prime the fuel pump" that doesn't make a difference at all. There seems to be no pattern when it will long crank or fire right up...other than the two examples I gave (getting gas, or not using the Escape for a day or two)...other than that it can fire right up or long crank. I am TOTALLY lost and no one seems to know...I have also been told by the two dealerships that it is NORMAL...but it NEVER EVER did this until about 5 months ago....anyone have any other ideas?
