2010 Hybrid parts not available
598 Views 4 Replies 4 Participants Last post by  Waloshin
Have found my 2010 Escape Hybrid very useful! However, now Ford is unable to replace a part, an automatic transmission shifter cable which is specific to the hybrid, a longer length. The Park position does not work-- the vehicle rolls and so the parking brake must always be engaged. I usually do that anyway so the vehicle is driveable. Additionally, the shifter movement feels soft. Ford and the dealer say parts for this vehicle are no longer being made and a search online found no availability elsewhere. I asked if they would buy-back the vehicle and was informed that it was not a requirement to do so under our state lemon law, so no they wouldn't. My only option seems to be to trade it in, as I wouldn't feel comfortable selling it myself. But the hybrid SUVs are costly as new cars and availability of used ones is very limited! Grrrrrrrr!
Welcome to the city, Lizzy.
First thing I would look into is whether or not the shifter cable is adjustable. Based on the images on the Internet, it may be.
Do you know what your part number is?
My first search on the Internet came up with several… You can also probably get one from your local salvage yard for very cheap.
you should probably get yourself a club to stick on the steering wheel… I am sure you cannot remove the key without it being in park.
10
Looked at the google search ... Tasca has this: (way down at the bottom ... hybrid 2010
Cable - Ford (AL8Z-7E395-A)
To fit:
  • Genuine:
    Ford, Lincoln, Mercury Parts
    Lincoln Parts
    Mercury Parts
  • SKU:AL8Z-7E395-A
  • Other Names:Shift Control Cable, Automatic Transmission Shifter Cable, Cable Assembly Selector Lever Con
  • Description:
    Escape, Mariner. From 12/9/09. Auto trans.
  • Sold In Quantity:1
Warning
WARNING: California Proposition 65
FORD
From the pioneering days of Henry Ford’s assembly line, quality has always been an integral component of Ford. Every Ford car, truck, and OEM part is tested to meet the highest standards of quality and functionality. OEM Ford parts and Motorcraft® parts are the original equipment replacement parts for Ford, Lincoln and Mercury vehicles and backed by Ford Motor Company. You can trust Ford!
This genuine OEM Ford part, when sold & used within the U.S., is guaranteed by Ford & Motorcraft Parts Limited Warranty.
ALSO PURCHASED
Gear Shift Assembly BL8Z-7210-CA
Gear Shift Assembly
BL8Z-7210-CA
$121.50
Mount Bracket 9L8Z-7B229-A
Mount Bracket
9L8Z-7B229-A
$16.31
Steering Column Cover BL8Z-3530-AC
BL8Z-3530-AC
$62.38
Drive Plate 1S7Z-6375-D
Drive Plate
1S7Z-6375-D
$30.28
Remanufactured Automatic Transmission Assembly BL8Z-7000-HRM
BL8Z-7000-HRM
$3,283.91
Cable 6L8Z-7E395-AA
Cable
6L8Z-7E395-AA
$68.25
VEHICLE FITMENT
YearMakeModelBody & TrimEngine & Transmission
2012FordEscapeLimited, XLS, XLT2.5L L4 - Gas, 3.0L V6 - Flex
2011FordEscapeLimited, XLS, XLT2.5L L4 - Gas, 3.0L V6 - Flex
2011MercuryMarinerBase, Premier2.5L L4 - Gas, 3.0L V6 - Flex
2010FordEscapeHybrid, Limited, Limited Hybrid, XLS, XLT2.5L L4 - Electric/Gas, 2.5L L4 - Gas, 3.0L V6 - Flex
2010MercuryMarinerBase, Premier2.5L L4 - Gas, 3.0L V6 - Flex
  • Like
Reactions: 1
After 10 years most car manufacturer most discontinue parts.
I guess the noise in the VVT and variable can timing making noise. I am not used to that.
