Want to see if same part number used for standard w/o sub and premium sound w/sub.
Thanks
Thanks
Thanks for the pic.lThe version with sub has a third plug on the back where the sub is connected. The ACM will work fine without a sub connected to it.
It isn't worth all that. Go aftermarket. The factory is at best, mediocre.Thanks for the pic.l
I removed the entire Audiophile Sound from an 08 Mariner: ACM, Speakers, Sub assembly thinking I would install all that in my 2010 XLT to get the upgrade.
But The Problem is that when I checked the As Built parameters, the 08 had something like 4 addresses specified where my 10 had maybe 16 - so I'm suspecting they are different and swapping won't be possible even if I tried to set the AsBuilt with FORscan
However, The Solution might be that Ford used the same ACM for all sound systems meaning I could hook up the sub, and switch some AsBuilt param in my 10 OE ACM and be in business. I know that with the sub, the EQ will have to be changed since the basic system has "boomy" bass in the doors.
I would post on the FORscan site but you have to buy the unit or sign up for a time limited free trial. I don't want to buy if it won't work, and I'm moving very slowly on this, so the free trail period would most likely expire before I could figure out my options.
Do you have SYNC? I think that might be the only major obstacle for running an '08 ACM in a '10 Escape. In my '08 I did the unofficial Sync upgrade that required a '09+ ACM in order for Sync to work. There are no issues running this newer ACM in my '08. So going backwards is probably OK as well. Also if your '10 radio has Sirius you will lose that as well since in '08 the Sirius receiver was in a separate module under the passenger seat.I removed the entire Audiophile Sound from an 08 Mariner: ACM, Speakers, Sub assembly thinking I would install all that in my 2010 XLT to get the upgrade.
I don't have SYNC in my '10 (but my neighbor's '12 does and I wouldn't mind having that (!)Do you have SYNC? I think that might be the only major obstacle for running an '08 ACM in a '10 Escape. In my '08 I did the unofficial Sync upgrade that required a '09+ ACM in order for Sync to work. There are no issues running this newer ACM in my '08. So going backwards is probably OK as well. Also if your '10 radio has Sirius you will lose that as well since in '08 the Sirius receiver was in a separate module under the passenger seat.
So as long as the Audiophile ACM does not require the external amplifier for the main speakers I would say go for it. The only real headache will be installing the wiring from the sub to get the sub connector to the back of the radio area.
Don't get too worried about setting the AsBuilt data in the '08 radio. The AsBuilt enables/disable software options in the radio mainly for optional features. Stuff like whether or not the steering wheel radio control buttons are installed or not. This is 99% likely already turned on for a Audiophile setup. If your '10 does not have the buttons on the steering wheel, the ACM won't complain, there just will be a DTC set that indicates a circuit failure for the buttons. And then you have another project to swap the steering wheel to add another factory option!
Thanks for the info.I think you are right that there is not a separate part # for the audiophile version. My '08 originally came with a 6 disc changer ACM (no sub or the third connector for it) and no steering wheel buttons. Based on that I am going to say that there were three part numbers for the non-nav ACMs in '08: 1. Single disc, 2 6-disc w/o sub, 3. 6-disc w/sub (audiophile?). And maybe the audiophile upgrade is just some different speakers (separate tweeters in the front doors) along with a tweaked EQ setting in the AsBuilt data? Unfortunately I can't seem find much info what can be changed in the AsBuilt settings for Escape ACMs of '08-'09-'10 vintage.
As you noted a '10 ACM is somewhat different/more advanced. '08 was a transitional year for the Escape and many things were one off for that year only (the V6 engine and transmission being the most significant). In '09 they started supporting Sync, included the Sirius radio receiver inside the ACM, etc. so that accounts for the extra AsBuilt params.
But I still think an '08 ACM would work in a '10 given that these systems are very primitive when compared to a current model vehicle. The physical connectors are all the same and the only dependencies the ACM has is to the radio controls button module and the FDIM for display readout. They all just talk on the MSCAN bus and don't interact with any other modules.
Oh and also be sure to change the 'Welcome String' in the FDIM so you can start enjoying the Audiophile experience before you start swapping parts . My now says "FORD ESCAPE AUDIOPHILE" when I turn the key on and I swear that makes the system sound better without even having a sub
I ran across threads of people adding SYNC. Seems to be a lot more popular than upgrading to Premium Sound (!)Hello All,
Now I do have a question... I have an 08 with 6cd changer with mp3... I want the sync feature on my 08, so the question is, besides the actual unit (radio) what else do I need to pull from a 09-12 to make it work? Also, mine doesn't have the steering wheel buttons but could I just swap the latter model steering wheel with audio control and will it work ?
I have also updated the Welcome Screen message on mine and I too swear the sound is better, even if I had not updated any speakers on the car itself hehe
