Since all 4 sensors in the rear are effected, or not detected by the PAM, we will focus on one sensor. Fix the one, and all four should be fixed.
Each sensor on the rear bumper have 3 wires. So, one wire will be 5 volts to the sensor. One wire will be less than 5 volts out of the sensor (signal). And one wire will be ground back to the PAM, not chassis, or frame ground.
Set the volt meter to the 10 volt scale. Testing will be at the came connector to the PAM, C4014. We will test the circuit for the outer, driver's side sensor. All tests are KOEO.
Find pin #9 at C4014, it will be a blue wire with a white stripe. This the 5 volts out of the PAM.
Find pin #12 at C4014, it will be a green wire with a white stripe. This ground to the PAM.
Back probe both pins, do you read around 5 volts?
There is no need to test the signal wire. Just power and PAM ground.
