Nice work, man! One question...
The stock head unit has a preamp output(s)?
That would need to be a pretty big inverter. Vacuum cleaners often pull 10 amps or more (1200 watts or more).AREscape said:Nice upgrades! I may have to install an inverter in my E! The thought of not pulling an extension cord to vacuum is reason enough!
Awesome work. I am just looking to install new sound system in car. Which will you prefer now?jeremy1701 said:
Howdy not sure if you already did your install but I am super impressed with my factory install that is simple and impressive. Could do the full install in 1 day and drive out booming with nothing looking "unstock" for around $600 or less, bluetooth A2DP included... no need for LOC either.1anndale said:I am looking to emulate this set up I just have a few questions before I get to it.
Is it hard to figure out which speakers are connected to which wires in the HU? I don't want to clip the wrong wires.
Also I understand I will need LOC's to run from the HU to the amp which I have purchased, but how did you run the sub from the amp, did you tap into wires with another LOC and if so where?
I am planning on running a LOC for the front speakers, and a LOC for the back speakers to the amp (5 channel), speaker wire back and out to the speakers and then wiring the sub to the amp. I just want to make sure I have it all right before I dig in.
Thanks!
