Is it possible to change the cigarette lighter from always hot to only on in acc/vehicle start?
My dashcam is taxing my battery if I dont drive daily & wasting data storage. I can turn it off but it disables parking mode.
Any ideas?
If you want "parked mode" then it needs to always have power, right? I assume that is a motion sensor that records when the car is parked? Most of those have 2 power sources, one is always on, and one is switched, so when switched it always records, and if not switched then only sensor recording.
I have done both, and never had good luck with the ones that have the sensor recording, but that also isn't something I am really interested in.
On my 2017 Escape I ran each power to a fuse tap in the fuse box under the dash, and didn't do the power point.
Park mode uses an internal battery. I'll look into the fuse trap, maybe the dealership can make the change over. Thanks!
For the f-150 they have mapped out the addresses and values needed in the BCM that you can modify to change the functionality and time remaining on for the power point(s), and can modify them in Forscan, but I haven't seen anything like that for the Escape, let along the fourth gen Escape.
