vansprink said:
I would like to know how the system really works, it might help me better understand enough to talk with a mechanic. so if its a electro-machanical clutch. mabie its something really simple like a loose wire or conection. i did check the fuses and there ok. like i said no warning lights.
From the '08 Ford Escape Workshop Manual:
Principles of Operation
The vehicle is equipped with an All-Wheel Drive (AWD) system, also referred to as Active Torque Coupling (ATC), that is always active and requires no driver input. The system has no Mode Select Switch (MSS).
The system continuously monitors vehicle conditions and automatically adjusts the torque distribution between the front and rear wheels. During normal operation, most of the torque is sent to the front wheels. If wheel slip between the front and rear wheels is detected or if the vehicle is under heavy acceleration (high throttle position), the AWD system increases torque to the rear wheels to prevent or control wheel slip.
The system consists of a Power Transfer Unit (PTU), 4X4 control module, rear axle and a solenoid actuated ATC device. Based on the amount of current sent to the clutch, the module varies the torque sent to the rear wheels by sending a duty cycle to the ATC device, located inside the rear axle. For concerns with the PTU, refer to Section 308-07B.
The 4X4 control module also provides the brake system with its current clutch duty cycle and determines whether or not the brake system may take command of the clutch duty cycle.
NOTE: The ATC solenoid is not repairable. If a new component is required, the ATC solenoid and rear axle are installed as an assembly. Refer to Section 205-02.
The active, on-demand AWD system uses data from other systems as inputs to the 4X4 control module. The 4X4 control module uses the inputs to determine the appropriate amount of current to send to the ATC solenoid that delivers the desired torque to the rear wheels.
Specific inputs to the 4X4 control module are:
• Accelerator pedal position via the High Speed Controller Area Network (HS-CAN)
• Transaxle range from the Transmission Control Module (TCM) via the HS-CAN
• Brake system status from the ABS module via the HS-CAN
• Wheel speed from all 4 wheels from the ABS module via the HS-CAN
4X4 control module outputs are:
• Solid-state clutch (pulse-width modulated signal) to the ATC solenoid
• Percent of torque transfer commanded signal to the ABS module via the HS-CAN
• Torque request available signal to the ABS module via the HS-CAN
Heat Protection Mode
During very extreme off-road operation, the AWD system utilizes a heat protection mode to protect the ATC solenoid (part of rear axle) from damage. If the system detects an overheat condition, it enters a locked mode. If the heat in the system continues to rise once in the locked mode, the 4X4 control module disables the ATC solenoid. Allow the system to cool down at least 10 minutes with the ignition switch in the ON position
