1 - 10 of 10 Posts
Ok, I was looking at a video that I had just recently posted and when I looked closer I noticed something kind of odd. I had the 4X4 mode engaged but the rear tires dont spin. Only the fronts are moving.
You will notice that the front tires spin a lot but the rear tires look like they arent even trying. I put my car on a gravel road, put the 4x4 lock on and then floored it but only the fronts would spin. My question is, Is my rear not engaging? Is there a way to fix this? I need your help please!
Do you have any ABS warning lights on? The ABS sensors are used to determine wheelspin.
No sir. I havent noticed the ABS light because I am not applying the brakes at the moment. I have read on the "other" Escape forum that this has something to do with the rear diff.
I have a silver lining to add to the cloud that is your diff repairs. :cry:
Just think how much better your off-roading will be when you're not stuck in 2wd! :thumb:
Seriously though, I hope it's nothing too serious. :)
HAHAHAHA, I was starting to think that too! :lol:
Well....I'm a fool.
All well though, atleast this means I dont have to repair the 4x4 system and I can spend more money on mods! w00t!
Use a lift or jackstands and lift that SOB up and put it in drive :wave:
Surfscape said:
I've seen the same thing with my 4x4 system (04). The early system delivers power to the rear wheels yes but at a reduced percentage depending on the wheel speed differential.
Which is why the front diff at least should have had an LSD in it from the start. :mad:
i got stuck in a field a while ago (i will have pics eventually) and my buddy said i had both rear wheels spinning once i lost traction and became stuck. im glad the guy that owns the place also owns a tractor haha. i would see the mud spraying from both front tires at the same time a few times. what are the chances of having an LSD in the rear? cause thats sure how mine was working. and i know i didnt Lincoln lock it. (for those of you who dont know what a lincoln lock is.. its when you weld your spider gears and lock your diff)
1 - 10 of 10 Posts
