anyone out there ever added an oil cooler to a 3.0 tribute or escape? is it simple enough to add on the factory cooler and hoses to an 03 escape-tribute?
thanks,
ed
why do you think you need an oil cooler??
Id like to do some light towing with my tribute, which came without the tow package.. from what i read the tow package had an oil cooler and most articles i read on towing reccomend an oil cooler. the tribute came with a trans cooler and im going to install the hitch and wiring, so if i can add on an engine oil cooler id feel good about towing up to 3000 lbs.
ed
trans cooler should be sufficient, i doubt your engine temps will go above normal towing 3000lbs.
