Exactly. And I had good luck getting to the fog lamps and parking lamps by removing only the front side of the splash shields on my '05.
For an '05 to '07 Escape, there's
no fog lamp bracket. It's part of the fog lamp assembly.
BUT, although the '05 through '07 fog lamps look the same from the outside, they're very different
inside.
The '05 and most '06 models use a
9145/H10 fog lamp bulb. Some late '06 and all '07 models use a newer bulb---Sylvania and Philips have different numbers for it, but
5202,
H16,
9009, and
PS24WFF all identify the same bulb. The older H10 and newer H16 use different connectors, and since you have an '05 (you should already have the wiring and connectors), you need to make sure that you use an '05 fog lamp assembly.
The '05 fog lamp assembly part number is
2M5Z-15200-AB. You should also have a blank fog lamp switch cover on the lower left side of the instrument panel. When you remove it, the connector will be attached to it already. Just unplug the connector from the blank cover and replace the cover with the factory fog lamp switch. The '05 fog lamp switch part number is
5L8Z-15A214-CAA. Also, make sure that you use the
'05 fog lamp switch, since it's also different from the fog lamp switch used on the '01-'04 Escape.
You might need to have the dealer flash the SJB, but it
may also already work.
Do not wire the fog lamps to the parking light circuit, since that circuit isn't designed to handle the extra current. The good news is that on '05 and newer models, the fog lamps light with the parking and head lamps, but not with the high beams.
