Ever since I bought my 2013 Escape Titanium I've thought the ambient lighting was too dim. On page 73-74 the Escape Owners Manual states the following:
AMBIENT LIGHTING (IF EQUIPPED)
The ambient lighting system illuminates
the interior with a choice of several colors.
The ambient lighting control is located in
the overhead console.
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/13204om4e.pdf
Ambient Lighting Button Group Picture Here
A Color palette
B Control knob
C Search mode
Rotate B past the first detent to switch on
and adjust to the desired brightness.
Press A to cycle through the color choices.
Press C to switch on all interior lamps and
the ambient lighting. Press C again to
switch off the interior lamps and return the
ambient lighting to the previously selected
color.
The ambient lighting will switch on when
the following conditions have been met:
• you switch the ignition on
• you switch the headlamps on
• the outside ambient light level is low.
The ambient lighting will remain on until
you switch the ignition off and one of the
• you lock your vehicle
• the accessory delay timer expires.
My Problem: I sense the detent when rotating Knob B but only when immediately turning the knob from off. The knob turns smoothly and does dim/brighten the ambient lighting but IMO not bright enough. Is this normal? The manual states "...first detent..." are there more? Every time I see a Ford picture depicting an interior with ambient lighting I laugh because this is definitely not what my interior looks like when the knob it turned all the way up. I appreciate any feedback you all have to give me. TIA.
A Color palette
B Control knob
C Search mode
color.
