1 - 7 of 7 Posts
I'm trying to build a laser pointer essentially. Anyone good with electronics like this? I bought a laser diode (5v), momentary switch, and some wiring. I wired it up with a 3v battery source and it works but unless the laser is on the wiring heats up HOT. I'd like for that to not happen.
Any advice?
Current limiting Resister.
with out knowing the Diodes number I can only refer you to Ohm's law,
3v souce /Current needed for the diode = resister needed.
I'm unclear on what is triggering the heat; you say "unless the laser is on," which sounds like the switch should be open with no current flowing at all....Is the 'off' position of your switch still leaving a circuit closed? (i.e. for an LED in an illuminated switch or NC contact wired to the battery terminals)
What is your wire gauge and battery type?
1 - 7 of 7 Posts
