I have my barely used Audio Control LC6i Line converter for sale. I had it installed in my 2010 Excape and no longer need it since installing a new receiver. It works perfectly to keep your factory HU and run an aftermarket amplifier. The unit takes the signal from the speaker input and uses that signal as a turn on remote out to power an amp. It converts the speaker in to RCA output.
I spent $125 on it new and looking to get $100 shipped OBO (US only). It was only used for 2 months. Perfect working order. I will also throw in the 2 Fosgate RCA cables. They are 3' in length. I don't need those either...
Here is a picture of when it was mounted to the rack.
Details:
Line Output Converter
Six input and output channels
Speaker level inputs
AutoMode(tm) inputs
Signal sensing inputs
Level matching controls
12 volt trigger output
Optional dash control knob with dual color LED (Dash Remote)
Remote-in, Remote out
Colored LED clipping indicator
Maximum speaker-level input: 400 watts @ 4 ohms
Maximum output level: 95Vrms
Output gain: ±12 dB
Frequency response: 10Hz-22kHz
Total harmonic distortion: 001%
Input Impedance: 20 Kohms
Output Impedance: 150 Ohms
Power supply: High headroom PWM switching
Power draw: 200mA
Recommended fuse rating: 1 Amp
Dimensions: 7" W x 5.15" D x 1.2" H
Owner's manual link:
http://rs.audiocontrol.com/company_38//LC6i_OM.pdf
Where did you find the tan sub box from???
