Sellin some stuff to fund my new build so figured I would see if there is any interest at the City!
First I have an Memphis 2 channel amp that has never had power to it.. It was mounted at a local shop at a display and I got it from the owner when he got the new models. Lets do $125 plus shipping on this. Comes with everything in box.
Next is some Rockford Fosgate 5x7 speakers. Bought them about 2 years back for a Thunderbird I had and a week later the motor went out. THey have been sitting in my closet ever since. Have 2 pairs of them. Will do $50 plus shipping per pair. Paid over $125 per pair. I do have a total of 4 of these. These will go good with the amp above so if you want both I can make you a deal.
Next is an Alphasonic PMA1000HCA. Got this amp in a trade for some subs. I have never used it but the guy I got it from is a good friend so this is guaranteed not to be DOA. (As is all the stuff listed) Here is some specs on it:
2 Channel High Current Power Amplifier
RMS Power Rating: 3000 watts x 1 chan. at 1 Ohm Mono
RMS Power Rating: 1500 watts x 2 chan. at 1 Ohm Stereo
RMS Power Rating: 900 watts x 2 chan. at 2 Ohms Stereo
RMS Power Rating: 500 watts x 2 chan. at 4 Ohms Stereo
Hour Meter to log amplifier usage
Remote mount Bass Remote control included
Remote mount Digital Voltmeter included
ANL gold-plated Fuse Holder included
Heavy duty heat sink
Beveled clear acrylic protective cover
Tiffany-Style input and output RCA jacks
High speed switching power supply
Double-sided glass epoxy circuit board
S/N Ratio: >100dB
Frequency Response: 5Hz-50kHz
Variable low pass filter: 50Hz-250Hz
Variable high pass filter: 50Hz-250Hz
Variable subsonic filter: 15Hz-60Hz
Variable bass boost at 45Hz: 0~+18dB
Variable phase shift: 0~180 degrees
Input sensitivity: 200mV-8V
Input impedance: 10K ohms
4-Way protection circuitry: thermal, short circuit, overload, and DC offset
On board hook-up terminals
Dimensions: 26"L x 9"W x 2-5/8"H
Would give it an 8/10 cosmetically,, 10/10 functionality
S/N Ratio: >100dB
