Sorry that I didn't reply sooner to this!
I didn't know that Escapes without automatic headlamps still have "sunload" sensors, so that's a good thing. Now you need to see if the headlamp switch connector has the extra wire you need for automatic headlamps.
This applies only to 2008 and newer North American Escapes, Mariners, and Tributes.
Remove the headlamp switch and look at the connector. If you have a
VIOLET with GREEN STRIPE wire on that connector (and a total of nine wires), then you
may have automatic headlamps. That depends on how the SPDJB is programmed.
To determine if you do have automatic headlamps already programmed:
* Move to a very dark location.
* Remove the headlamp switch. See this how-to thread:
viewtopic.php?f=27&t=1510
* Remove the connector from the headlamp switch.
The headlamps will turn on. Don't worry about this.
* With a small piece of solid telephone or hookup wire (24-26AWG), CAREFULLY jump the pins on the headlamp connector that lead to the
BLACK with BLUE STRIPE wire and the
VIOLET with GREEN STRIPE wire.
* Start the car, then shut it off. If the headlamps stay lit for several seconds and then shut off, you
do have automatic headlamps, and you can order the optional headlamp switch.
The part numbers for the 2008-2009 Escape and Mariner headlamp switch (with blue lighting) are:
8L8Z-11654-AA -
without fog lamps,
without autolamps (about $20-$25)
8L8Z-11654-BA -
with fog lamps,
without autolamps (about $50)
8L8Z-11654-CA -
with fog lamps,
with autolamps (about $50)
I don't know if the 2008-2009 Tributes also have blue lighting, but the switches listed above will work on those models.
Please let us know if autolamps work on your Escape.
